07HDClassic
Can the dealer find out if I have used a OBD2 programmer on an 07 LBZ?
Just make sure you pull out the Tune before going to the Dealer and you should be ok.
I took it into the dealer to find out what might be going on. The dealer was making sure I haven't been using a programmer for the sake of my warrenty.
Sounds like you might have Overboosted a few Times and broke a Seal somewhere in the Turbo, and are now getting Blow By.
Or could be from the PCV also.
If the boot was leaking enough, my fuzzy logic would say that's why it gave you the under boost code. As others have mentioned, the boots are sometimes prone to blowing off or leaking. Add some oil into the mix a la the PCV system and the boot could give you problems sealing until completely cleaning it and re-installing.
If you take the boot off, clean it and the mounting surfaces with acetone to remove the oil residue, spray the boot with hair spray and re-install with the clamps this should keep it from blowing off again. The hair spray acts like a lubricant at first, then dries and forms an advesive holding the boot on along with the clamps.
The oil vapor from the pcv system which is pulled through the induction system will "condense" and settle into the low areas, which in our case is the intercooler. It is unfortunately normal to see this. It also causes the soot generated by your egr system to turn into a black gooey gunk and stick to the walls of the intake pipes.
Re-routing the pcv and blocking the egr will solve this problem once you take everything apart and clean the oil and soot out.
