jhornsby3
Active Member
I replaced the heads gaskets and heads not long ago. When I replaced the gaskets I had the coolant "shake" in the oil system. When I removed the pass. side valve cover there was 1" of the water/oil "shake" covering the inside of the cover. Had the heads skimmed and pressure tested and all was good. Now if that crap was in the valve covers, how long will it take to work that crap out of the lower end? I flushed the system with oil/ tranny fluid to remove it from the workings. There is 150 miles on it since the repair and there is still water vapor coming from the dipstick and the CDR. I'm getting blue white smoke from the exhaust at lower RPM's and today when getting off the throttle on hills. It's not alot, but it's there. There is no new crap in the oil just the CDR and at the top of the dipstick.
Today it got warm when heading out and when I stopped to check things, noticed the top hose wasn't even pressurized like it should be. The water in the overflow tank was cool enough to pop the cap amd put a finger in. Topped the tank bled some air and reved the engine a couple times to 3k and bled out a tad bit more air.
If anybody has some advise out side of some sticks of TNT, Please.
John
John
