The installation was too messy with the transmission fluid for any photos, as I did the install alone. The overall installation was very simple. I did a simple drain of fluid from the stock Allison pan. After the pan stopped dripping (30 minutes or so), I put the drain plug back in. I unbolted all of the bolts and carefully dropped the pan straight down, as there is still a good amount of fluid inside the deep pan. Be sure to have a large pan to catch all of the remaining fluid that continuously drips from the inside of the Allison Transmission valve bodies, etc. The OEM rubber transmission gasket for the pan comes off with the old pan, and is reused with the new PPE deep pan. After a while (another 20-25 minutes), I then removed the old filter. You pull it straight out the bottom. Be sure that you also remove the orange colored gasket from the old filter from inside the transmission where the filter goes into. I then installed the new deep pan filter, and installed the new deep pan slowly making sure to tighten up the bolts evenly. After going through the tightening process a few times and making sure the pan was secured properly, I started to put the new fluid in. Be sure that you follow the process for checking the fluid. There is a cold check and a warm check. As you fill the Allison with fluid, you must start the engine, and with the brake on, go through the gears, from R - N - D - M - 1, and back again a few times to get the fluid running through the transmission, and converter. All fluid checks are done with the engine running. It is my understanding that you do not want to overfill the fluid, so check carefully and accurately. I slowly added fluid several times, until I was just over the middle of the fluid area on the dip stick for both the cold fluid check and the warm fluid check.
Prior to the installation of the PPE deep pan, I made sure that the drain plug and the fittings for any gauges were properly secured. The drain plug is very nice, and is magnetic and comes with a rubber o-ring on it.
Install was very simple and very easy.
