Fysh Guide
Fysh Guide
I can't seem to find enough info anywhere so I thought I'd see if anyone here could answer this.
My power steering pump is getting leaky and squeaky so I want to R&R it and I want to replace it with a high output unit, around 1500 psi. As some of the lines in the P/S, hydroboost and gear box circuit are weepy and worn, I want to replace them with high pressure AN6 braided lines and adapter fittings between each component. The problem is I can't find or eyeball the sizes of the ports on some components without removal.
I believe the Pump is three M16x1.5 ports and the P/S gear box is two M16x1.5 ports. The hydroboost isn't so simple. All three lines appear to be different sizes. Does anyone know what sizes these are? I want to have all the adapters and lines ready before I start. I'm also going R&R the rag joint between the gearbox and steering shaft at the same time....
Thanks
Dan
Thanks
Dan
