Year: __2000____
- Truck model and class (ie: c2500) _____k3500____
- Automatic or Standard ____auto______
- Mileage: (indicate miles or km) _107k________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _______Nope just oil and air filt____
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ___F___________
- Ambient outside temp: (indicate *C or *F) __________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ______Ultra low sulf___
- What fuel additives are you using? __Sulfer boost_________
- Where are you located? _______Youngstown area Of Ohio______
- Air filter _last yr________
- Fuel filter _last month________
- CDR Valve? __IDK_______
- Coolant – last flushed/replaced at _IDK____________
- Oil – synthetic/regular, changed at __Place purchaced at_________
- Batteries – state of charge, (matched set) replaced at __Duralast___________
- Battery cables and grounds (removed, cleaned and tightened): ___tightened___________
- Glow Plugs - how many miles on them? ___Stock______ What type? _________Stock____
- Injectors - last changed at __Stock_____________
- What were you doing when it happened? _______Doesn't work_______
- How was the truck running fine before this problem appeared? _______Yes______
- Has this problem ever happened before? __apparently it doesn't work_____________________
- Describe any related factors that might be part of the problem. __________No over head lights____
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _N___ And? ___N_____
Diagnostics:
1] Starting:
1a] Does the engine start? ______N___
1b] Does the engine crank over? _Y_______
1c] Are your batteries fully charged? __Y_______
1d] Have you removed, cleaned, and tightened all battery connections? ______Y__
1e] Does your Wait to Start light come on for a time? How long? _Y 10 sec ________
1f] Does your glow plug light come on? _______Y__ For how long? __10 sec_______
1g] Do you see smoke from the exhaust while cranking? What color? _____normal___
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _____stock location______
3b] Condition of Extension harness (if used) Vendor or Homemade? _____NO____
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ______IDK___
3d] PMD Make: _9__________
3e] PMD Age: _____9________
4] Stalling Issues
4a] Do you experience stalling only when hot? ______N______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ____N__
4c] Does pouring cool water over the IP seem to help with restarting? ___N______
4d] Is stalling momentary (engine recovers)? ___N______
4e] Does SES light come on when engine hiccups? N_________
4f] Does cruise control quit working when engine hiccups? _No cruise________
4g] Does re-starting seem to reset engine, restoring cruise and power? _____N____
4h] Changes to dash lights or instruments during stalling events? _______N____
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ____IDK___
5b] Any bubbles or oil film in coolant overflow tank? ___N____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? N__________
5d] Excessive white smoke from exhaust on cold start? ___Not really______
5e] Excessive black smoke from exhaust under hard acceleration? _____N_____
6] Performance Issues
6a] Do you have gauges? ________N___
6b] Maximum boost under load? ___What ever stock is_________
6c] Have you added a performance PCM (reflash) or Chip? _N_____________
6d] Have you changed exhaust / downpipe / crossover? ____N____________
6e] Wastegate – mechanical or vacuum? _______Stock_______
7a] Single or dual thermostats? ______Sing______
7b] Have you replaced them lately? Manufacturer of replacements? _____N____
7c] Have you pulled and cleaned Radiator and coolers lately? _______N_____
7d] Have you replaced the fan clutch? Manufacturer of replacement? ____N____
7e] (winter) Have you tested your antifreeze? Good to what temp? _____Yes winter over_____
7f] (winter) Are you using a winter grille cover? ___N________
