DennisG01
With OBDII:
I recently installed a new PMD (I guess it's actually called an FSD, now). Originally, there was a #5 resistor in there. Now there is a #9. Truck runs fine, but I wonder if the ECM still thinks there is a #5 in there?
So, I searched for the answer... I found some answers saying "No, you need a Tech2 (or similar) to do a TDC Offset Learn". I found other answers saying you can do some type of KO-KO procedure.
Then I found this one by Turbine Doc:
"warm engine to >170F, then shut down truck, put APP to floor, then with ignition key in run, not start; hold APP to floor for 1 minute, this will initiate the learn after 1 minute on then turn ingition off for 1 minute and APP in normal position, start truck and the new resistor code will be learned, also this will let the PCM learn the current TDCO setting."
So, can I do a re-learn without a Tech2?
