I am doing a cummins+NV4500 swap in my Suburban. I need a new set of pedals so I will have a cable throttle and a clutch pedal. I know that the 93 and older diesels had mechanical pedals and could have came with a NV4500, but there aren't a lot around. Will the pedals from a gasser work? Do they have hydroboost brakes or vacuum brakes? If they are vacuum, how do I need to modify the pedals to make them work on my hydroboost equipped suburban?
