Avoid WIX plastic fuel filters. Carry a spare fuel filter and tools to change it.
The oil is good for the GM oil monitor life of just under 10k miles with ONE exception: high % of biodiesel. The post injection with biodiesel likes to contaminate the engine oil. Try and avoid 20% pumps and keep it under 5%.
You will find some grades where the ECT likes to warm up, but, not enough throttle to downshift. You should manually downshift.
And most importantly make sure the heated washer fluid has been removed as GM's undersized wires for it burn the truck down.
