DIYORPAY
- Messages
- 98
- Reaction score
- 0
I seem to have the same trouble as trainedpro. (see limp mode) At WOT going up steep hill, truck only i have 10 psi on autometer gauge in cab and i de-fuel and ses light comes on.:mad2: This is on the 96 truck in sig. I took a snapshot and this is what it said.
Calc Load....................100.00%
ECT..............................186 deg. F
RPM..............................2835
VEH Speed....................64mph
IAT.................................264 deg. F
I erased the code and hooked up a cheapy boost gauge to see if my gauge was off and it read 12 psi when it de-fueled(same hill wot):mad2::mad2:
I need to tow 9000lbs (5th wheel camper) for about 600 miles. How can i do that without de-fueling? It happened almost instantly after towing it 20 miles last time. Will an intercooler by itself allow me to tow? Also.....i have a GM5 turbo. What is max(under load) psi i can run without going into limp mode?
The intercooler is on its way here(Thanks Jim!!) but do i need more or should that suffice? ATT,GL4 would be nice but not yet.
Thanks.....Brian
Thanks.....Brian
