My .02...
... @WillL, if you don't recommend a holset 35, 40, hybrid, or ATT, what do you recommend?...
(I edited quote for space/ relevant to question)
The OP mentioned specifically the hx35. Imo that turbo is too small still for his application. He doesn’t need mega torque like an off roading truck in the first few hundred rpm. He is going to need the power from 1400 rpm lowest up to maybe 3700 rpm. Mostly hiway use. So a set up like what WarWagon did with the stall converter and the ATT, Or an hx40, both would be good answers. I believe Quadstar had a turbo bigger than the 40 with a wastegate- another possibility. I am only ruling out the hx35 -and of course the GM chokester.
On the 5.9 liter or 360 cid cummins which only designed to hit rpm of 2850 iirc. 3,000 was in the red. That was a proper fit for hx35.
The 6.5 or 396 cid doing another thousand rpm...
4 stroke math
CFM= CID x RPM x VE / 3456
VE = Volumetric Efficiency
0.9 for naturally aspirated diesel engine
1.60-3.0 for turbo charged diesel engine depends on turbo size and if inner cooler and how well.
Look at the engine cfm without a turbo to compare what turbo ought be considered:
360x3000=1,080,000x.9 =972,000 / 3456= 281.25 CFM for the cummins
396x4000=1,584,000x.9 =1,425,000 / 3456 =412.326 CFM for the GM.
The GM is moving 1.466 times more air than the cummins. Almost one and a half! And people think the hx35 is maybe too big for a 6.5? Haha. No it doesn’t translate exactly like that to sizing the turbo, but when you are dealing with a rig that is going to focus on hiway use- letting that sucker breathe is huge.
Thats why imo to save this guy money long term, and to make it more useable, and with less overheating possibilities- I wouldn’t spend over $100 trying to get the gm6 to work. Why? It ought to be mounted on a honda ricer racer where it belongs. Why do I push this so strongly? Because I did it to my hummer KNOWING it was too small but justified it by cost at the moment. Money wasted. Time wasted. Worked the engine harder than it should have been. My hummer is at 10,000 lbs, but I would put a dollar to a donut his weighs more. Mine is like a brick wall going down the road, but his is like the whole brick house. To compare it to a pickup towing a trailer it would have to be a monster load to have the weight and the wind resistance.
I took it from the beginning he had some kind of accepable budget to work with. $20,000 should do it no problem. I wouldn’t push him to a new radiator- his could be fine. Get the proper cooling system in there- most likely the AK Diesel Driver mod of elecectro-viscous fan and clutch- and depending on turbo MAYBE a water to air cooler. Big non wastegated ATT shouldn’t need it. Stuffing the turbo in there, running all the pipes and oil lines is gonna cost some labor. A customized dog house is probably in the future too. But well worth it for the difference. Stuffing a tall and long cummins in there would do the same. And btw, dmax- yeah, big centermount turbo also, so same dilemma. Suck it up buttercup. Doing a custom bus means custom. So getting it to go from gubmint paid for tow truck on demand to self sufficient and more reliable means make changes.
