What are you going to do with the truck? Towing heavy on grades the GM Turbo is an Asthma Attack as I published the results of a big ATT turbo here especially the MPG improvements as the load is maxxed out:
http://www.maxxtorque.com/2012/07/the-65l-diesel-factory-equipped-asthma.html
Your use may vary and there are many different turbos out there now. Getting an understanding of the trade offs in RPM appears to be the biggest surprise. Generally the huge turbo won't light below 2000 RPM, most other popular turbos also suffer some at lower RPM, but when they lean you back and pull like a freight train all the way near, to, and above redline it's worth the trade off. I have seen many want to lug the diesel like the Asthma Attack turbo likes and are surprised when the big ones can't spool and just smoke. With the extreme heat, AC on, and cooling fan locked up I suffer the worst off the line. I solved the problem with a high stall converter and have the best of both worlds. Instant 2000 RPM off the line, huge turbo lights off, and trouble keeping the rear tires from spinning even with a trailer on it. Without this you need to shift sooner and put up with a delay before you get enough RPM to spool up leaving a stoplight in a hurry.
Case in point: the RPM the Asthma Attack chokes at is where the ATT has lit off and will show you the real power a 6.5/6.2 has. IMO a 1993 gas 454 feels blah vs. the hopped up 6.2 in Patch. Others on here
@n8in8or could hold their own vs. a lighter Trailblazer SS that has a 395HP 4400 Ft LB Corvette LS2 revved to 6500 RPM in it.
