One piece rear main
SnowDrift
Ultra Conservative. ULTRA!
Central Ohio map dot
According to this, is it safe to say I can use a one piece rear main seal since my pan is a 1995?
Happy New Year SnowDrift. Ohio played a good game last night.
Rear Main Seals. More to the point, Your block determines the seal you can use (one or two-piece), not the pan.
If the block you’re using is designed for the 2-piece rear main (like mine, a 660 cast 6.2L), you’re going to need a matching 6.2 pan. Just learned Missy’s points about pan differences at the rear main for myself.
FWIW, I had to have the SCAT crank turned down to accept the 2-piece seal so it would work in my block.
Yes, we watched that and missed the ball dropping which I actually enjoyed more (although they ran out of time).:happy:
The engine I'm asking about had a 2 piece rear main seal. The pan was that of a HMMWV. The block is a 2011 Optimizer. Based on what I'm reading, I already have what is needed for the 1 piece?
I don’t think it needs any coating applied.Just polished to a mirror like finish I would guess is all it needs.Maybe someone else might know the answer.
Just wondering about the scat crank journals….are those induction hardened?
