Hink
Overkill Is Underrated
So I was able to finally roll my truck into the shop today. Just getting set up and started is always the hardest part on these projects it seems, but changing the NV4500 transmission in my ’93 GMC 4X4 actually looks like a straightforward process.
As per the Factory manual the steps are essentially to remove or disconnect;
1- Shifter
2- Oil
3- Drive shaft/Transfer case
4- Slave cylinder
5- Inspection cover
And now you’re ready to…
6- Support the tranny with a jack
7- Remove the crossmember
And
8- Remove the four bolts from the bellhousing
Now pull her loose!
And of course, things in reality aren’t so simple so I’ll go through some details as I go along.
First, I jacked her up and set her on the best jack stands that I could find.
My shifter screwed right off by hand and I removed the four screws holding down the boot collar.
And then the screws holding the boot.
I pulled the gaskets off.
Then I went down below and pulled the skid plate with a torx T50, disconnected the linkage with a screwdriver (it just pops into a rubber grommet), the vent hose, electrical, drained the oil and removed the driveshafts. I also pulled the carrier bearing mount loose so I could move the rear driveshaft aside.
Now I removed all four tranny mount bolts, lifted the tranny until I could pull the mount out and slid a 2x4 across the torsion bars right where the mount was and lowered the tranny.
Now I drained the oil from the transfer case, removed the six bolts and pulled it loose.
Lowering it was a bit hairy but it came down ok.
So here I sit.
I removed the four bolts supporting the transmission to bellhousing and am ready to lower it down but the shifter stub is getting in the way and I can't figure out how to get it off!
I know it's push and turn but that's not working. Anyone have detailed info?
1- Shifter
2- Oil
4- Slave cylinder
5- Inspection cover
And
Now pull her loose!
So here I sit.
