2003bigsilverado
Recruit
- Messages
- 59
- Reaction score
- 0
Do I stay with my Wix or try a synthetic filter. It's said that the synthetic filters work better and last longer. Any thoughts?
Ive heard WIX filters were pure trash...
Wix will do you just fine. . .
I have done this:
if you own a GM use AC-delco filters.
if you own a FORD use Motor craft filters.
if you own a DODGE use Mopar filters.
I have used the Vehicles manufactures filter as they should idealy filter the oil properly for that vehicle.
I have also done this:
Mobile 1 oil Mobile 1 oil filter.
Valvoline oil Valvoline filter.
AMSOIL oil AMSOIL filter.
I have use the same brand filter as the oil as it also should filter the oil in spec as well.
I don't use Supertech filters or frame filters as they are half the price for a reason i'm sure. . .
Mikey
really ? the Super tech holds up ok ? they just run smaller ?
I may have to give them filters a try as I run AMSOIL but i change my oil filters 3 time per oil change. . .
my first AMSOIL service on a motor i spin a filter every 1K and dump the oil at 3k. . .after that i run 3k on a filter and 9k on the oil . . .
This new info Might just save me some cash as them Supertech filters are much cheaper to replace. . .:thumbsup:
Mikey
