just a number
Active Member
ok guys here's the scenario.
I've got an aftermarket cooler with an adapter at the filter. the original ports are looped together. I have to redo the loop section in order to clear the clutch.
my question is,would it be better to just use the original 3/8" ports or keep the 1/2" with the adapter? would it make any difference to the engine or cooler or the the 1/2" just overkill anyway?
any opinions/ suggestions?
