Oil cooler connector
matuva
Tropical 6.5er
We're on the way to install a Ted's 6.2l in a 1997 K1500. Everything is going fine, but we forgot one thing: the 1997 K1500 uses high flow hoses which are bigger than the oil lines found on 6.2l and early 6.5ls...
Soooo, we have to match the 1997 oil cooler lines with the smaller oil cooler line connectors found on the 62l...
We so need connectors which can bolt on the 6.2l block (3/8 if I'm correct), and can receive the 1997 cooler hose , 14 NPT x 18.2 mm on the hose side.
Of course, we could cut and weld, but we like to have nice parts if they exist
Any body knows if such connector exist, where to find them, part #?
Yeah, that's what I'm afraid of too...
I know the opposite does exist, I mean connector which bolts on a 506 block, and allows to use small lines from a 141 or a 599. I have found them for the install of my 6.5l Ted's on my Blazer.
But I wasn't sure about the ones I need to install a 660 in place of a 506... Thought I should ask though.
I can set you up with the step up/down in fitting sizes. (do it all the time) People change engines from older trucks to newer need the same. I sell a few kits a week like that.
I have just the fittings or complete kit on my site.
I Will check what I need, depending on the year of the 3 trucks still to receive a 6.2l, and I'll PM you ASAP
