GM Guy
Manual Trans. 2WD Enthusiast
Hey guys,
funds are a little short this time of year for me, so after buying some amsoil from
wrecker, I dont have much left over for oil cooler lines.
I called the dealer, and according to VIN the lines needed are 15104803, and 15104800.
so here is what I did: i bought this new old stock line, this one was the 4803: http://cgi.ebay.com/ebaymotors/ws/e...0178775163&viewitem=&sspagename=STRK:MEWNX:IT
and will be buying the mate to it (15104800) shortly.
I know, factory lines leave something to be desired as far as reliability, but I figured that new OEM is better than used original lines that are leaking, right?
So I am here to ask you fine folks if I still need to buy the block adapters, and if so, which ones?
On rock auto, the connectors listed are 15027502 ac delco, and the dorman equivalent.
if I buy two of these 15027502 connectors, and the 4800 line, will I have everything necessary for new lines?
rock auto does list under the oil cooler tab: ACDELCO Part # 88960976
RETAINER,ENG OIL CLR CONN.
is that just the plastic line holder at the rad. support?
thanks, guys, and sorry that I couldnt support pmdcable.com this go around, I will be sure to buy some more boost fittings come guage time.
