Question - have you gotten o-rings installed on a 6.5?
For readers unaware of what o-rings are, here is a DIY video. Personally I'd leave it to a machinist, but the video is insightful.
- What has your experience with them been? Good, bad?
- Did you groove the block or the heads?
- What wire material did you use, copper or steel?
- What gasket did you use - Mahle, Fel-pro, Cometic? 0.010" thicker, or stock?
- What were the dimensions you went with (protrusion, thickness of the wire, diameter of the wire, etc.)?
- Did you have any issues rebuilding or resurfacing block/heads that were previously o-ring'd?
