Big T
This is an old problem on the NP 246 transfer case in my 1999 K2500 Suburban: 4Lo does not work. Light on button just flashes. 2Hi, 4Hi and AWD all work.
I recently replaced both 4L80e transmission and the NP 246 transfer case. Also bought a new AC Delco encoder motor which did not work per my mechanic:
"Transfer case would not shift after replacement. Test power and grounds to motor = ok. Replacement shift motor is not moving. Installed original transfer case motor and test - 4wd now functions properly."
He missed the part about 4Lo not working, which is why I bought the new encoder motor. 4Lo still does not work. Light on dash button just flashes endlessly. Everything else works. New reman transfer case came with HD aluminum case half that addresses the pump rub issue.
Given that the AC Delco encoder motor did not work, I am sending that back as it was purchased on Amazon.
I still face the issue of no 4Lo. I have a CKO GM Tech 2 Scanner. I plugged in the scanner and got these screen captures:
Not sure I am using the Tech 2 properly. I tried to find how to run test for TCCM specific codes, but could not figure that out. Is this point to the Transfer Case Control Module (TCCM)?
