Cumminalong
Doghouse Diesel Performance
Doghouse Diesel Performance is now an authorized dealer for Hellion Power Systems and can now offer BOLT ON twin turbo systems for your Hemi Powered SRT-8 Challenger, Charger, Magnum and 300C.
Kits are also available for Ford Mustangs, Cobra's, GT500's and Lightnings from '79 up.
Coming soon are kits for the 2010 - 2011 Camaro.
These kits are capable of putting down over 500 HP on otherwise stock engines with only 5 psi of boost and pump gas.
They're capable of supporting 1000 HP in built applications.
http://www.youtube.com/watch?v=LqjmArvoIDs
Example of the components included in one these kits is below:
2 - Turbonetics Turbos
2 - Turbosmart Ultragates
8 - SRT-4 52lb Injectors
1 - 180 Thermostat
1 - Intercooler
1 - O2 Sensor Extender 19"
1 - SRT-4 MAP Sensor
1 - Oil Scavenge Pump
1 - Oil Pump Bracket
1 - Oil Scavenge Tank
2 - Oil Drain Flanges
1 - TurboXS Bypass Valve
1 - Driver Boost Pipe 1
1 - Pass. Boost Pipe 1
1 - Pass. Boost Pipe 2
1 - Y-Boost Pipe
1 - Bypass Boost Pipe
1 - Polished Throttle Body Pipe
1 - Driver Side Downpipe
1 - Pass. Side Downpipe
1 - Driver Side Up-Pipe
1 - Pass. Side Up-Pipe
1 - Driver Side Wastegate pipe
1 - Pass. Side Wastegate Pipe
2 - Cat Pipes
1 - Driver Side Flow Tube
1 - Pass. Side Flow Tube
2 - 3" x 2.5" Long Straight Pipes
2 - 2.5" x 2.5" Long Coupler
2 - 2" x 3" Long Coupler
1 - 2" x 4" Long Coupler
2 - 2.5" x 3" Long Coupler
1 - 2.5" x 7" Long Coupler
1 - 1.25" x 2.5" Long Coupler
1 - 4" dia. 90 degree Elbow
2 - 2.25" T-Bolt Clamps
8 - 2" T-Bolt Clamps
6 - 2.63" - 2.94" T-Bolt Clamps
2 - 1 5/8" Exhaust Clamps
4 - 2.5" Torque Clamps
2 - 1 - 2" Worm Hose Clamps
1 - Worm Clamp for -8AN Hose
2 - 4" T-Bolt Clamps
2 - 3/8" Hose Clamps
6 - 3" Worm Hose Clamps
1 - 37" 4AN Braided Hose
1 - 41" 4AN Braided Hose
1 - 7.25' #8AN Black Pushlock Hose
1 - 18" of 1/4" Vacuum Hose
1 - 13" of 1/4" Vacuum Hose
1 - 4.5' of 1/4" Vacuum Hose
1 - 18" of 1/8" Vacuum Hose
1 - 3" dia. 24" Long High-Temp Hose
1 - 3" dia 8.5" Long High-Temp Hose
2 - 1/8" NPT Male to 4AN Male Fittings
1 - 1/8" NPT Female T (Brass)
1 - 1/8" NPT Male to Male Union
1 - 3/8" NPT Male to 1/8" NPT Female
2 - 1/8" NPT M to 1/8" NPT F 90 (Brass)
2 - 1/8" NPT M to 4AN M Check Valves
3 - 3/8" NPT M to F 90 (Brass)
2 - 1/2" NPT M to 8AN M 45
3 - 3/8" NPT M to 8AN Straight
1 - 1/2" NPT M to F 90
1 - 1/2" NPT M to 8AN M
1 - 3/8" NPT F to 8AN M Straight
1 - 3/8" NPT F to F Check Valve
5 - 8AN Pushlock Straight Hose Ends
2 - 8AN Pushlock 45 Hose Ends
4 - 1/8" NPT to 3/16" Barb 90
1 - 3/8" NPT Female Brass T
2 - 3/8" NPT M to 3/8" Barb
1 - 3/8" NPT M to 1/4" Barb
1 - 1/4" Barb Vacuum T (Plastic)
1 - 1/4" Barb to 1/8" Barb Vacuum Adapter
18 - 8mm x 1.25 x 20mm long allen head
2 - 8mm x 1.25 x 30mm long allen head
4 - 5/16" coarse x 1" long allen head
4 - 8mm or 5/16" flat washers
1 - 10mm x 1.5 x 40mm long stud
1 - 10mm Flat Washer
1 - 10mm x 1.5 Nut
4 - 10-24 Pan Head Bolts
4 - 10-24 Nylock Nuts
2 - 6mm x 1.0 x 90mm Allen Head bolts
2 - Spacers for Scavenge Tank
1 - O-Ring
8 - 3/8" Coarse Set Screws
8 - 3/8" Coarse Flange Nuts
Call for pricing on these kits.
1 - 180 Thermostat
1 - Intercooler
1 - Y-Boost Pipe
2 - Cat Pipes
1 - 10mm x 1.5 Nut
1 - O-Ring
