docdray
Oompa Loompa
yes, cannot find exact problem or solution with search. Here or other place.
Ran through checklist, here is pertinant summery:
In Houston, 5:30am, 80 degrees, exit hwy, light changes, come to quick stop. immediately truck dies. absolutely no trble up to this point. no start, truck cranks slow, like 3X load on starter and no cylinder fire. tried new pmd-same results. jump start-same result. towed home- charge and load test batteries-their good. rechecked cables-good. jumper cable to starter-same. grounds cleaned 4 months ago. no codes. normal glow plug cycle. fuel good to injectors.
so, everything ok, then quick stop-now starter cranks heavy and no indication of engine wants to run???? no strange noises either. what could cause a seeming increase in engine friction or lug down starter instantly?
