Mudbath
Old Smoky
My truck starts out in 2nd and stays there. I have checked for 12 volts (ignition on) at pin "E" on transmission and it is good
Tested as follows
1-2 solenoid resistance (a to e pins range 20-40 ohms) was 22.4 ohms, good
2-3 solenoid resistance (b to e pin range 20-40 ohms) was 22.4 ohms, good
pcs solenoid (c to d range 3.5-8 ohms) was 4.5 ohms good
tcc solenoid (e to s range 20-40 ohms) was 11 ohms bad
I added some trans conditioner to see if maybe one solenoid is stuck (I suspected the 1-2 solenoid)
Codes 81, 82, and 83 are coming up and if I clear them they come right back without even driving it.
This is our daily driver so I need to get it fixed asap. Any body have any ideas?
Thanks in advance, Bob
Tested as follows
