6.5TD Burb
Is is possible to have a clogged fuel filter and it be as white as it was when installed? What brings this up:
Reading 0 fuel pressure. Mechanical gauge installed between filter manager and IP. When it cranked it would build up to 7psi and promptly fall to 0 when it ran. New OPS, new LP. Dropped the tank to check the sock; it was most definitely dirty but I wouldn't call it clogged, at least IMHO. Opened the bleeder on the filter manager (hot wired LP and when running) and nothing came out, not even air.
