Newbie's C3500 6.5TD Saga
coachjpg
boston
I wanted to learn about diesels, so I got a PennDOT '99 C3500 with the 6.5TD and 175K on it. School bus yellow. I've rebuilt motorcycles, so I have a clue, but Diesel is new to me. Though the info in this post is probably obvious to the masters, it took a lot of web reading for me to assemble. I'll summarize here, in hopes that other newbies might find this useful.
On the 6-hour drive home, in the wee hours, on the interstate in the middle of nowhere, the "Water In Fuel" light came on. Now I'd made it a point to fill up at a truck stop so I'd get clean, dry fuel. Oh well.
I pulled into a very dark, very empty rest stop & pulled out the manual. It did not mention a "Water in Fuel" (WIF) light. It did mention that I should look at the Diesel Supplement. Of course, I had no Diesel Supplement. So I called the 800 number for Chevy's 24-hour customer support. Nice people, not useful. So I pulled out my netbook, got on line and came to TheTruckStop.com. Folks said I should open the brass valve on the thermostat, but no one said where the thermostat is. Air-cooled motorcycles don't have thermostats. I finally found pictures. It's the little T-shaped brass valve at the top front of the engine, a little toward the passenger side of center. I bled 18 oz of water before I got diesel. I know because I was filling empty plastic bottles. The WIF light stayed off after that.
Some might question the wisdom of taking a 6-hour journey in a newly acquired used truck. I had my netbook and all my tools. I also had Allstate Motor Club's RV insurance, since AAA doesn't cover a 1-ton Dually pickup. (They say it's too big.) The truck had been serviced and inspected. I had no pressing engagements. I made it OK.
Next, I wanted to know if the fuel filter needed to be changed. I learned that the fuel system wants about 5 PSI feeding the injector pump. There's a pressure valve on the fuel return line that cracks open when the pressure reaches 5 PSI, letting fuel return to the tank. So I want to measure 5 PSI at a point between the fuel filter and the IP. The pressure at this point can go negative, when the IP is pulling harder than the lift pump is pushing, so the sensor needs to measure both vacuum and pressure.
I was looking at a wiring diagram, and noticed fuel pressure sensor wires feeding into the computer and/or PMD. I figured, why add sensors if they're already there? So I got CarCodes.com, and learned that the existing pressure sensors are not where I want them. CarCodes does provide great access to what sensors exist. I like the "soft" gauges on their dashboard.
I'm careful to bleed off fuel regularly and check for water. I bleed it into a plastic bottle so I can see. It's become a routine act, and today I was carefully watching for fuel to come out of the hose when I realized I'd been opening that valve longer than usual. Then the engine died. Bummer.
The bleed valve connects to the dirty side of the filter. Since fuel wasn't coming out, that means there was no pressure to the filter. It seems the lift pump had died, so the IP had been doing all the work to pull fuel from the tank. That's hard on the IP. I had checked for water that morning, and gotten good flow, so I'd been running without a lift pump for less than a day. When I opened the valve with a dead lift pump, the IP sucked air in and the engine died.
Why check for water in the fuel twice in one day? The truck had sat for a week or two while I worked on the bed, and I thought perhaps there might be condensation in the tank. I'm still learning what to expect with this truck. I figured running a few errands would run any water through the filter, where I could drain it out. I was curious to see if I got any water at the end of the day.
When you have no fuel pressure, everyone says to jump the fuel pump relay to run the pump. I found lots of instructions on how to do this. Many were for other 6.5 models. Some were flat wrong. If you pull the fuel pump relay, the pins underneath the relay are labeled. I put a voltage tester on mine, and pin 87 is always hot. Several web articles said pin 30 led to the lift pump. So I jumped 87 to 30, and heard the pump run. I opened the T valve and the bleeder valve on top of the filter, and got no fuel from either.
OK. The tank is 7/8 full. The lift pump is making noise, and we have no fuel to the filter. Something could be blocking fuel to the pump, but since the engine ran fine before I tried to bleed it for water, restrictions seemed unlikely. Any restriction that blocked the lift pump would also have blocked the IP, but the IP managed to pump the fuel just fine. Evidently the lift pump failed in such a way that it still makes its usual noise, but it no longer moves fuel.
So I went and bought a new lift pump from the local parts store, as well as flare wrenches and their best penetrating oil for freeing rusty bolts. I had to scrape off rust so I could get the wrenches on the fuel pump fittings, and they were so frozen that I stripped the nut. A 5/8 flare wrench on a 5/8 fitting, and all it did was mangle the corners of the fitting. The wrench rotated, but the fitting did not. So much for the top-end penetrating oil.
So I couldn't replace the lift pump. So I put a funnel into the bleeder hose, opened the bleeder valve and the filter bleeder, and poured diesel into the funnel. When it came out the top of the filter, I closed the bleeder valves, and started the engine. It had to crank for a bit, due to the air in the injector lines I imagine, but then it caught and ran fine. I wouldn't run it much like this, but it works well enough to drive to my local mechanic, if I need to.
So now I guess I'll have to replace the entire fuel line, from tank to filter. I tried to find a fitting that would go from my new lift pump to 3/8 hose, but the pump fitting is not NPT. I guess it's 3/8 straight threads. I think I'll return the OEM pump I bought and get a Walbro with the fittings I need.
I also need to get to the top of the tank. They say it's easier to remove the bed than to drop the tank. OK. I broke off 8 of the 12 3/8 in carriage bolts trying to turn the nuts. One I drilled out, one had no nut so I drove it out with a hammer and punch. The last 2 were the most fun. They were carriage bolts that spun freely, so I had to cut off the nuts with a dremel cutting wheel and a cold chisel.
I need to get a lift so I can get the bed off. It's a utility body, so it probably weighs over 500 lbs empty. Once I have it off, I can access the fuel tank and replace the fuel line with 3/8 rubber. At least that won't rust! I'll also do what I can to get rid of the rust on the frame. I'm looking at some combination of naval jelly to remove rust, picklex 20 to convert any remaining rust, and Rust Zero to paint the de-rusted frame. I'll also be using wire brush, cold chisel, pressure washer, and elbow grease to remove existing rust.
So imminent plans include removing the bed, replacing the rusty fuel line with rubber, de-rusting the frame, and installing a pressure gauge between the filter and the IP. Then come the recommendations made elsewhere on this site: spare remote PMD, ground refresh, feed the beast, etc.
I hope someone finds this post useful. I'd have been sunk without this site.
Thanks everybody,
-jpg
PS I know some folks would prefer pictures. Sorry, don't have any yet. I'll try to add some.
welcome to the site....I am sure that the owners of these 6.5 will chime in with alot of help.
Welcome coach............WOW talk about baptism by fire. You have dealt with some of the typical trouble stuff on 6.5 right out the gate please dont get discouraged on these brutes the bunch here can get you through just about anything. And I do mean anything. ):h:grouphug::D
"The bunch here" is how I got this far. Thanks guys.
-jpg
Welcome to The Truck Stop, coach! You won't find a better crew of knowledgeable, friendly guys anywhere.
Help us out a bit and fill out your signature with details of your truck and what you've done to it so far. Click on the signature link (in my signature) and it will take you to yours. We need to know what modifications you have already made - it helps with diagnosis, and keeps us olde fartes from having to try and remember what truck you have (or running back to square-one all the time because we can't)
Jim
:welcome5: howdy howdy, glad you found us and glad your 1st post was a success, be sure to let your friends know about us, while we are fluent in 6.5s (no better site for the 6.5 IMO) we speak to all flavors of Diesel here be regardless of mfr.
Oh for the lift pump fittings metric is what you need, a LOT of metric fittings on these, majority of the fittings/fasteners are metric
Here is the underside of the fuel pump relay, and the jumper I used. Below the pins on the relay you can see numbers. On my '99 C3500, #87 is always hot, even with the key off. #30 goes to the lift pump.
There are many differences among model years. This is what worked for me. YMMV. Be careful!!
Here you can see the jumper in action, sending power from #87 to the lift pump via #30. My pump makes the usual "purring" noise, but no fuel moves. (This is the same purring noise you hear while waiting for the glow plugs to heat up before starting the engine.)
Other posts talk about how the fuel pump relay only sends power when the oil pressure sensor says there is oil pressure. This jumper bypasses all that, so you can see if the lift pump works if it gets power.
When I opened the bleed valve with a dead lift pump, the IP sucked in air which killed the engine. Here you can see the funnel I used to mostly replace that air with diesel. I opened the T valve and the fuel filter bleeder, and added diesel until it came out the fuel filter bleeder. Then I closed both valves. This got the truck running again, though without a lift pump, so I'd only use it to drive to a repair shop.
This also shows the brass T valve normally used to bleed fuel/water/sediment from the dirty side of the filter. That junk normally comes out the hose that I connected to the funnel. So I'm sending diesel back through that hose into the dirty side of the filter, displacing the air sucked in by the IP.
(The fuel filter bleeder is on top of the fuel filter, which is not visible in this photo. Other posts address the fuel filter in detail.)
rusty fuel tank fittings
Today, I slid the utility body back so I could get to the tank. More rusty fuel lines.
I'm not prepared to replace the tank today, so I guess I'll just cut the rubber, connect to that, and leave the tank fittings alone for now. I'll clean it up and hit it with rust converter for now.
Tomorrow I go after the fuel manager.
Any words of wisdom are more than welcome.
Thanks,
-jpg
Thanks,
-jpg
Do you mean sending unit???????????
I dont remember you saying your fuel manager was bad.
Mine locked just as bad with only 70 k on the clock...................
I would spray the crap outa the lock ring with your favorite pentrating oil. Have fun the lock rings can be a real PITA.
My sending unit works. It's rusty, but it works. I plan to treat the rust and leave it alone, for now.
My immediate task is to replace the dead lift pump. The fuel line fittings are corroded, so I'm replacing them with rubber. Given the state of the sending unit, I'll cut the rubber hose and tap into the tank that way.
New fuel tank and sender are now on my list,but not for today.
New pump is working. I get 7 PSI on dirty side of the filter at idle. It's a fairly new filter, so I'm guessing we have 5 psi at the IP. Next steps include replacing rusty return line, putting the utility body back, and testing on the road.
I'll publish new pictures when I get to road test.
-jpg
New fuel lines are in and working. I treated the rust on the tank and the sending unit. I got the bed off and back in place by myself, using lots of 2X4s and the truck's jack. Tomorrow I bolt it down, reconnect the lights, and test drive.
There's a lot of frame rust. I'd appreciate any words of wisdom folks might have as to how to treat rust. This is not a show truck, but I do want to keep it functional long term. I did some reading, including the threads on this site, and wire brush, Picklex 20, and Rust Zero sound like the best approach. I ordered a bumper crane that will make it easy to remove the bed so I can get to the frame.
I know what you are going through I purchased a crew cab single wheel from penndot also just finished it up though for the rust I use a rust enscapulator from eastwood it has never failed me whether on jeeps motorcycles or pickups. Good luck with the bed my bobcat wouldn't even pick up the whole utility bed off my pickup.
