flhtc01
As I have posted before, I have a new to me 1986 CUCV. I am experiencing some different issues. Any input would be appreciated.
1. When cold starting it takes forever. New Duraterms with bypass relay. GPs are working. When I say forever it take about 4 to 6 cycles of the GPs of 15 seconds each time and it was 38 degrees out today. It has set for two days and it has been plugged in. Am I supposed to be giving it fuel? It will try to start and run for about a second at what seems to be a higher than normal idle. Once the truck is warmed up it fires right up with no issues what so ever. The initial is just brutal.
2. How can you determine whether or not the block heater is working?
3. The water reservoir keeps getting low and I can find no signs of leaks anywhere. Where are the normal leaks in these trucks? The oil is NOT milky and there is no indication of it steaming from the exhaust. After the running the truck and getting it to temperature there is no sign of leakage on the ground. Confused.
