Mad Maxx
See, what had happened was...
I just Changed the Fuel Filter On my Truck, and whenever I'm Working In an Area, I Look around the whole Area and Check Things Out, See if I Notice anything Outta Whack...and boy did I See something.
This "Clip" Holds the Passenger Side Battery + / - Cables, and another Small Wire to the Frame so they don't Shake around or Hang Loose. Upon further Inspection, I Saw the Metal Clip was Partially Rubbing through the Jacket On the Cables. So I Unbolted the Clip, and Chucked it. I Secured the Harness another way that I felt was good.
So Check this Spot On your Truck ASAP!! There are +12v Cables, and Ground Cables that are Ran Through this Clip.
