crash2win64
Hey I'm new here, been reading for a little while and just decided to sign up today. I just bought a 98' CCLB 4x4 3500 SRW truck last week. Got it for $2200 with broken crank in motor and pulled the motor last weekend. Block is cracked around #2 main web and into the cylinder bores and crank seperated itself from the front two cylinders from the back six. I've never seen that one before.....
So yea basically just getting into this whole 6.5 business lol. I'll have a block ordered tomorrow and start from there when I get it. So I have a few questions pertaining to build up of these motors and any help/suggestions would be appreciated. I do have a little experience with gassers and build up of them so I have basic concepts down.
Anyone use block filler on these? I plan on doing about the bottom inch or so of the water jacket to help with strength.
What cranks are you guys using? I planned on using a Scat
I planned on using stock pistons and rods from the junk motor as those are fine because basically crank just let loose from itself and motor didn't run after. If that makes sense I dunno lol but parts are still good at any rate.
So I'll also be doing head studs, main studs, balance rotating assembly, port and polish the heads, and pretty sure about a gear drive.
And the other thing I'm wondering is if the groundworks laid right with these engines how much boost can practically be thrown at them?
I've been reading about this but kinda lost on some things...maybe a lot of things. I just read the 5 page thread about the ds4 and flow and am totally lost there....
Thanks,
Joe
Thanks,
Joe
