fbh31118
Cadet
Been without a job for a few weeks now. Friend of mine has been hauling cars with his truck and mentioned it to me as a possiblility for some short term employment.
Here's my question; I know that I need to do a complete fluid change (ie: oil, cooling system, front and rear diff, transfer case, power steering, yada, yada, yada.) I've added a secondary fuel filtering system, Merchant Auto transfer case pump upgrade, replaced the belt, rear end fluid(mobil one 75W90, a squeeky idealer pulley and a driver side wheel bearing.
What other things would you suggest as things to look at or add to my truck, it is bone stock with no performance upgrades or programmers. The truck has had 0 problems since I bought it in the early spring of 2007. I know that I should add some gages for boost and egt but is there anything else that I should consider? What about a power steering cooler? Go back to heavier front and rear end fluid?
Oh, forgot to mention that the truck has 81,000 miles and the injectors were replaced under warranty at 35,000 miles and I plan on pulling a two place, goose neck car hauler (all the truck would be legal for). Any thoughts on this or things to check
