Needing some help
smokymtn65
East TN
Replaced heads about 30,000 miles ago. Building pressure in cooling system now. I have right side down everything looked ok visibly. Took head to local shop no cracks ( I am amazed) asked him to pressure test anyway. So what to do now? Pull it and go through it check for block crack? Or clean it up good and reinstall hoping it was a gasket... Suggestions.... please.
I am planning on a turbo upgrade 35 or 40 I am running a 8 now. near future upgrade will include a program and WTA intercooler also. Thanks
If you would have pulled the thermostat housing first and started it you could have watched for bubbles and known which side was causing issues
Usually the cracks are visible. Usually run verically
Visual inspection shows nothing other than a nice cross-hatch pattern. Guess I will clean it up. chase and clean the threads good and put her back together and say a prayer. Thank you for your responses (BTW your neck of the woods is on the bucket list for the Burb!)
Well after so long a time.... culprit found. Blown HG #7 give a little test time then back to upgrades one piece at a time!
