WestVdiesel
Ok everyone for the past year my truck would not “hot start” if i shut my truck off it will only start if I immediately start it back up or wait an hour or 2 depending on outside temp i do not have this problem in the winter but as summer is coming around this problem has re-risen now as of yesterday my truck is sitting in a parking lot becuase it shut off on me as if someone turned my key off and no matter what it would not start back up now a year ago i replaced the pmd and relocated it to the inside of my bumper well away from engine heat the truck lately has had rough idle but not all the time it would hiccup and almost act as if “cammed out” ....i will attemp to start the truck once i get off work in the morning usually after sitting awhile it will start up what are the possibilities it is an optical sensor problem or possibly the ESS on the pump i know the lift pump is in good working order it has a good flow of fuel to the IP also could it be my PMD again even after the relocation any help is appreciated idk what it could be i dont trust turning my truck off in fear of it not starting back up “only in the summer months” the truck is a 98 gmc k2500 6.5 with marine injectors a team turbo kojo tune 4in straight exhaust 4l80 tans i have been running this setup for a lil over 2 years now
