john65td
Addicted to boost
I have spent the past half hour looking at schemitics on all data and have gotten no where. i lenghtened the leads to my alternator and when i plug it in the battery light on the ip turns on. the fuel gauge and coolant gauge read way off the charts. i did tap into the pink fuel solinoid wire in the 15 pin connector at back of engine for a hot with ingition on for the fuel solinoid and that made all the warning lights come on so i undid that. i regrounged the grounds on the right rear of the engine block maybe its not a suffecent ground? and for the four whel drive connector the flat 4 pin gray connector i have lost the male end its not in the harness like all data said. im not sure if its because im exhausted or what but i'm missing something here thanks for the help
