Dropped this in on the 1993 during the last oil change. The hot summers have let the oil pressure drop ~2 ticks above the red at hot idle. AC on over 110 degrees out. GM was never that good about oil pressure on diesels for whatever reason. Regardless it was low enough to concern me.
The Mystik® Synthetic Blend 15w-50 got the pressure up by 2 ticks on the gauge at hot idle.
Note grounds and high current demand from the HVAC blower, headlights, etc. can affect the gauge reading. Before oil change grounds were addressed as well as new OPS that reads the same.
My 2005 Duramax also drops oil pressure at hot idle with synthetic 5w-40 oil. It has an alarm at 9PSI that hasn't gone off so it is ok... But guess what is in it's future for oil. :agreed:
