fastjohnny
I haven't seen pics yet, it's got 285K. Current owner has had for about 60K since 2007. PMD is on a cooler, but on the intake, has been changed a couple times. Interior/Exterior is good for age/miles, A/C leaks, 1 new battery,new alternator,new starter,new front brake pads rotors calipers. It will probably need front end work, ball joints/idler/pitman, etc. Now the big one: bad trans, owner states the bell housing cracked, as did the flexplate. If it was just a blown trans, it'd be no big deal, but at this stage, I'm not sure yet, whether I can start/idle it.
Any ideas on what would cause the bellhousing to crack? My concern is if that gave, could the crank have taken a load as well?
What's it worth?
What's it worth?
