Chicago TDP
Recruit
- Messages
- 87
- Reaction score
- 0
Well, it seems that my truck's millage and age is catching up finally.
I have just reached 214K miles and the truck took a turn for the worst. It has been doing great lately, 20 MPG, great power, started every time. I did have a P0216 code a couple times pop up but it is not on now.
Here is what happened. I was driving the truck home last week and it died right in front of my house after I was driving for about 20 minutes. I was about a block away and had to be somewhere so I locked up the truck and got in my Nova and took off. Came back a couple hours later and the truck fired up and sputtered but I was able to get it home.
The next day, I fired it up, no problem, no codes, and took off down the road. It was driving fine for about 5 minutes and then it just died. I was able to restart right away, drove another 1/2 mile and it died again.
Towed it home, and that night, I checked everything I could as far as connections under the hood. Nothing popping out at me as bad wires or anything.
So, I just figured that maybe the PMD died. Ordered a new one, no help. Truck still does not start.
I can crank and crank and crank and there is nothing.
I checked:
Fuel shut-off solenoid is working, opens and closes.
Lift pump is pumping and making 7 PSI at the pump
Batteries are all charged
No codes right now.
Pulled an injector line and there is no fuel coming out as I crank the truck over. Not a drop of fuel.
Any thoughts on what I should check next.
I checked:
No codes right now.
