My take on PCV Reroute
Ed HD
Formerly: Dad's 05 LLY
Chuck Town, Iowa
So, I undertook a few projects today, one of which ended up being a PCV reroute. I had a few bar stool caps around, and decided to look at it. Instead of the cutting I've seen others do, I just got some 5/8" heater hose, and stuck it on the nipple on the inside of the piece that goea into the intake tube. Took a little bit of heat, and a stainless hose clamp, and I was in business. It's totally reversible, literally had to modify nothing.
Sent from Behind the Pine Curtain
I don't think you can get away with this on the LBZ or LMM as they use a molded plastic tube instead of this type of setup. Also ne coul use the 01 catch can and set it up lik an LB7 to catch and re-use the oil that gets pushed out through the PCV.
