bobbiemartin
Author of The DB2 Conversion Guide
I thought I would post my current project. We are the original owners of a 1995 Suburban 6.5 1500 2WD. I have done a a few mods through the years, mostly for reliability. On of the biggest was to convert to a DB2 pump as I got tired of the DS4/PMD problems. The pump is a 4974 marine injection pump, also has Bosch marine hi-pop injectors, GM4 with TurboMaster, HO cooling upgrade with dual stats, a later round filter air box with K&N filter and a 3" Mandrel bent exhaust. I also have a Racor fuel filter installed before the lift pump. It also has Bilstein shocks, GM aluminum wheels and a WT grille with Cibie H4 headlamps.
Its pretty much a second vehicle now and has 185,000 miles. A while back, an oil analysis revealed that it may have a broken piston ring. A subsequent oil analysis confirmed that its getting worse, so it was time to make a decision. We contemplated selling or trading it, but we really like it and decided that spending a lot of money is not a good idea right now. So I decoded to repair it. I'm on a pretty strict budget, so getting a new GEP 6500 Optomizer (my first choice) was not an option.
I found a used engine and transmission that I think was a good deal. It was supposed to be a 1993 with 130,000 miles and a Goodwrench rebuilt 4L80E with 10,000 miles. It was removed for a Cummins conversion, so I'm reasonably sure its OK. After getting the engine, I found its a 1997 506 block. I contacted the seller and he told me he bought the truck form the original owner and he never mentioned replacing the engine. I'm not thrilled about the 506 block, but I have removed the oil pan and all looks OK, so maybe it will be all right. Its going to require a few changes to make everything fit. I also discovered the new trans has a bolt on yoke, the Sub a slip yoke, so I have to sort that out. You would think GM could keep everything uniform, but I guess not. I also have a few mods planned while its apart.
I have the old engine & transmission out. If anyone is interested, I can post my progress on this project.
