guybb3
My tank sock was clogged with the coating that is on the inside of the tank. There was a ton of stuff floating around (tiny metal flakes) and the sock would only stay clear for a day or two after blowing through the fuel line backwards with compressed air. I just got it back together and now it has the fuel flow it should have had. My fuel gauge had just started to wildly jump up and down as well, so I just broke the two metal lines on top of the sender (much easier to remove the tank that way) and replaced the sender and sock unit.
