I had the white smoke symptom again and this time it was not injectors. It was worse.
Headgasket on the left side. #6 had coolant in the cyl. The right side gasket had been replace around 30-40K back and it appears from what the tech says that it was leaking oil like it did the 1st time around.
He also found some bolts missing that apparently were left out as well as a turbo gasket missing. It appears the Chev dealer in Mishawaka, IN didn't do the job on the right side quite right. There is no other explanation for the missing parts.
This is a $3500 to $4000 repair job.
