Suburbank2500
Hi
As i promised, here is some pictures from my custom Intercooler project.
I got me a used, dented hood. Startet to straighten out the hood.
Cutted out the piece from the donor hood(Subaru Forester Diesel).
After carefully measurments i cutted the hole in the hood.
The donor piece matched the curves on the GM hood very good.
Then i started to test fit the Cooler in the engine bay, to get the correct height. and make romm for selings, and movements of the engine. When all this fidling was done i finished the hood, primed it with epoxy primer, and filler.
Painted the cooler im matching color. Some pics from the paint shop.
Then i made some covers to protect the electronic, and the fuel pump, i figured that there could be some dirt, and water "flying" in.
I made the cover in a way so it would not stop the airflow to cool the pump, and FSD cooler. The piec on the right in the image side is the one covering the pump.
Next pictures shows the covers installed.
Then it is pictures of the brackets for the cooler.
Two pics of the intake, and the way i cut it to make it fit.
As you can see i turned the intake 180 degrees. This way i have room for the electric pull fan.( from a Toyota)
It makes it alittle bbit troblesome tho change the fuelfilter, but i figured thet will be ok.
Then we have som pictures of the routing of the "plumbing", and the finished hood all installed.
Børge
Børge
