Darkrider
Lobo Solitario
Hey Guys i have a couple more questions about fuel system upgrades i am considering for my truck. I have seen mention of lift pumps being mounted in the bed in a thread i read on here recently. I am looking at the Walbro pump that Burning Oil sells and i was wondering if it would have enough power to be able to feed the engine if i were to mount it in the box with an inline pre pump filter. Also would it affect anything if i were to use the lift pump bypass kit i got from Burning oil with my fuel sending unit and keep the fittings in the stock location allowing me to install a stock lift pump in an emergency situation. Basically run hoses from the stock lift pump location to the box. Would that work or would that be too much line for the pump to be able to pump the fuel through?
