hey tanman, do you think that the extra quart through the shifter hole will raise the oil too far and cause excess churning and aerating? if you need extra oil capacity, as well as cooling capacity, this is what we ordered for my boss on his 4500.
http://www.ebay.com/itm/251046665318?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
he was getting by without them, but figured extra protection wouldnt hurt. he only used one, and will use the other on the DRW 03 Dodge. (the one that got to haul a 9230 Steiger!
)IIRC, he will be putting both on the left side, away from the exhaust, as long as the front driveline doesnt interfere.
there are a few others out there for more money, but IMO this is by far the best bang for the buck. Quad 4x4 has a filter system that mounts to a PTO cover that looked better than nothing, so maybe consider that.
searching "NV4500" no more, no less, no spaces yields about all the aluminum coolers you can get, NV5600 might yield a few more results as well smae PTO pattern on both, so no worries on compatability.
good luck!
@ Aaron1505 (which, btw, does that stand for 1505 massey ferguson?) I think the extra clearance was for soccer moms that fire up, and lay in it hard without allowing warm up. IIRC, they are aluminum pistons, which expand quicker than iron, so maybe a few scored motors from soccer moms may have prompted the sloppy clearance?
IDK, just heard of a guy that has an F-150 with a triton, never towed in its life, and was his baby. didnt rod it hard, or abuse it much, and cruising down the highway, it locked up. full of oil, 120K on the clock. plus all the spark plug changing fun, etc. makes me glad I am a GM owner, no matter the motor.
the one biggest pet peeve I have with the 5.7L (and it may have been only in the vortec) was akward intake clamping angles, aka, the bolt didnt go straight through the intake, and that caused a wedging effect that was partly to blame for its love of intake gaskets. IIRC, the OEM head gaskets werent very dex-cool compatable either ( I know ours sure werent). basically, the 5.7L was a good motor, but in the quest for more performance, they went to the LS series.
GM didnt abondon the 350 though, it is still being produced, and I got a brochure at a far show for an GM Powertrain 5.7L V8 power unit for use on a irrigation well.
they wont completely kill a good thing, unlike ford, 300 inline 6 is not obtainable in any way shape or form. that is also my opinion of fords last good motor.
everything has its faults, but they are all good motors (5.7L and LS)
