Suburbank2500
.Hi
I am about to start an exiting upgrade\refitting.
1.
I have a top mounted ATA cooler already, but it turned out its to restrictive (thanks to Buddy for calculating my CFM needs for the new ATA cooler)
Although, i got nice intake temps when cruising without towing in 80-90 km\h (17,5 degrees)with my present cooler it pops of the hoses on the turbo side when towing the caravan that is 2000kg.
Still got ok temps towing (50-65degrees) in 80 km\h with the turbo working at about0,5-0,7 psi, but if i put the pedal to the floor it boosts the hoses of, and they are clamped good.
I am going to use a cooler with this dimentions: Core 600x300x76mm\76mm intakes. It flows 700 CFM. ( the old didnt flow over 200CFM):nonod:
Will also install two slim line pull fans if there is room for it, one will fit for shure.
2.
A-team turbo
Will be happy to remove the GM thingy..
3.
K-47 airfilterhousing, with AFE pro dry filter.
4.
3 Banger MPC from Buddy
So its just one thing to do,:smash:away.
1.
2.
A-team turbo
3.
4.
