Well, I have driven my suburban almost 5k miles since replacing the transfer case and adding an lift pump manual relay. I made the mistake of moving the optical sensor after watching a video, wrong answer ,now the truck runs great except after it warms up it will not idle smoothly in neutral, it will idle smoothly in drive sitting still. I had to go into the optical sensor 5-6 times to get drivable power back. Should I consider trying to adjust the os again ? I live in a cold weather situation, the truck will idle alot during the winter.
