TMHark
Had a crappy positive battery connection on driver side battery. Didn't catch it till it gave me a problem.
The old girl cut right out a couple times before I found and corrected the problem. Volts down, stall, coast, start right back up when volts came back up. Now all shiny and tight. Truck runs great...
until... I do a real hard pull, almost when you feel that "damn, shift already" to get back on the torque curve. There is a blip like you snapped your foot off the throttle and then back on. I might be being paranoid but once it blips hard, it almost feels like there are barely noticable mini-blips that follow.
No stalls, or lack of power (and now no voltage drop :rolleyes5 It doesn't have the same feel as when my PMD or IP were failing in the past.
I did notice that during one of the couple voltage losses the "service throttle" light came on. Could this voltage loss (off-on off-on while running) have damaged the TPS?
Any tips or hints?
Any tips or hints?
