lock up converter mod
chessie 6.5
pennsylvania
Ok. I know I need to use pin c11. But there are two plugs at the computer/PCM that have a pin c11.:mad2: A pink plug and a blue plug. BTW both c11 wires are blue, one of them has a white stripe.
So, which color plug at PCM? thanks
It's the 32-pin blue connector... look in the 6.5 Technical library... there are ECM Pinout diagrams in there, I believe.
Jim
thanks, I did, but the references were confusing. Heath refers to a brown wire. Mine is a 1994. I just wanted to be sure. Don't want to fry the pcm.
Heath is referring to the connector off the side of the transmission. There are two styles of those. On one style, the sire is brown. Mine actually looked purple, and it was 94, too.
Pin C11 off the blue 32-pin connector is the right one if you're going off the PCM.
Jim
