ripmf666
Registered user
LLY 3" ProFlow Short Bridge $ 368.00 Shipped quote is to Continental USA Only Coating is $ 25.00 extra
This all 3" bridge & tube kit will flow what you need on the LLY! This short version allows you more flexability than the full version. The OEM bridge is opened up inside and a flow divertor welded in for better flow.
It also deletes the EGR so it's Off Road Only & best when used with a 3" boost tube.
There is a $100 core charge for the OEM bridge included that will be refunded if you return your old bridge CLEAN within 2 weeks.
