BigBlueChevy
Compression Ignition Addict
It was a great time and everybody had alot of fun. Even had a little bit of a scare at the end of the dyno day as the truck wouldn't start. Thanks Tim (Turbine Doc) for giving a few pointers on where to start as far as diagnosing what caused this. Somehow it ended up being an ECM fuse... and hasn't reoccurred since.
17 trucks showed up in total. 14 Cummins of various generations, 2 powerstrokes, and some joker with a 6.5L :rofl: Highest HP / Torque was a 6.7L Cummins hitting 500+hp and just shy of 1200ft/lbs of torque with a dying CP3 and spraying nitrous. The dyno however is was really only designed for cars, as it could only simulate a 3800lb load, so there where troubles with turbochargers lighting too late. So if anything the numbers on the Torque side could be a little off. I HAD a video of the truck on the dyno, but the @$$hat I asked to take the video felt like adding his own commentary during the whole thing and it becomes EXTREMELY irritating.
As far as spec's go for my truck its slightly modified 95' GMC K/1500 with an "S" vin EGR 6.5L and a 4L80E Automatic. Factory claims 180hp from the engine, not factoring in parasitic loss from the drivetrain. Mod's include a full exhaust (SS 2.25" crossover, 3" DP, 4" for the rest, and a 4" MBRP muffler fitted with the louvers away from the engine (backwards)), fluidamper HB, DMAX 21" fan, Marine nozzles, and my own blend of the "feed the beast" mod.
I did 5 pulls total. With the the first one being used as a test run to dial things in. The lowest pull was 164hp and 265ft/lbs. The best was 205hp and 525ft/lbs. The average between them all came out to around 195hp at 4200rpm and 385ft/lbs at 1650rpm Some of the spikes on the DYNOJET showed that those higher numbers came due to shift spikes from the truck wanting to drop into 2nd gear and take off. However, after some practice, I was able to roll into it a few times without downshifting and got the above numbers. Overall, I'm very pleased. The truck did way better than I expected it too, especially without an ECM tuning and the GM4 turbo choking the engine off. I feel there would be an amazing amount of potential unlocked from this engine with an HX40 / ATT and the proper ECM tuning.
