So, finished fabricating the homemade turbo master on the 'burb. Thanks to all who created a thread for the DIY guys to home grow their own. Mine is kind of a hybrid between ideas... will post on that later....
So, got all the parts installed, and went to adjust. With boost gauge installed (through the driver's window for test purposes) I closed in on 11 or 12 psi, and then the SES light came on... okay... so backed it down a bit. Reset code... drew it down to about 9 psi... sustained about 9-10 psi, then de-fueled no SES light. I'm assuming it was IAT was way too high (90°F here)...
soooo... I backed it down to 8 psi. I can gun it all day long, no smoke, no defueling, up to 80+MPH.
Now for question one... for those of you running the ATT, and other varieties of turbos... what is the difference between running a lower boost pressure (reducing exhaust turbine restriction in a GM-x turbo) and higher boost with higher IAT's vs the ATT setup?
And for question two... if you go above the IAT temps allowed by stock computer, it just defuels with no SES light? No scanner or other goodies to chit chat with Mr. Microchips. It just defuels until key cycle? Wondering out loud about this and how the computer handles it? Will it return to normal fuel levels should the IAT's come back into a "normal" range?
