Leaky Coolant Reservoir
Big T
Fullerton, CA
I was out in this beautiful 76 F weather tracing down a coolant leak on the '99. It's coming from the driver's side corner seam of the coolant overflow reservoir.:rolleyes5:
So, if I'm to hunt one down in a bone yard, do the gassers use the same reservoir?
Must be expensive because of that complicated low coolant light sensor. Its a crazy complicated setup with its own separate processing module, that could have been simple with a float switch.
