J.Peart
Active Member
So, i just redid the heads and cam in the truck, as well as a blown head gasket and i've been losing coolant. I found a couple leaks at the heater hose quick disconnect and the t for the rear heat. Fixed those, although i'm not too confident with the fitting. But that's another issue.
I thought that was it, but then i found some lovely 'snotty' looking goo in the CDR tubing:mad2:. I can get pics but when i have seen this before (not in person though) it has been coolant and oil mixing.
There isnt any excess pressure in the coolant system so i dont think the headgasket is gone. I dont see any signs of coolant in the oilpan, but there is only so much the dipstick can show.
Has anyone tied using the sealant tabs i have heard about to seal ARP studs?
This is the second time i have put them in and they leaked both times. this time I was super careful. I cleaned the bolts, chased and dryed the threads and installed as per the instructions and they still leaked. (i used the white permatex thread sealant).
If the coolant tabs aren't the answer i will probably try pulling the studs one at a time and rtv siliconing them in.
Any suggestions?
Any suggestions?
